Advantages of Metal Flooring in Your Boat
Metal flooring is one of the best choices you can make for your boat. Other commonly used materials for boat flooring include fiberglass, vinyl and wood. The type of material you choose for your boat floor has an impact on the durability of the vessel. This is because some materials have higher resistance to wear and tear than others. The boat floor material also plays a role in functionality. If you opt for metal, you can count on the following advantage.
Ease of Installation
Metal floors can be constructed with relative ease. This is partly because very little or no bevel lofting is required. This makes it easier to fit the floor. A metal floor requires shorter bolts than some other floor types. It also utilizes fewer bolts and fastenings during installation. This helps to keep installation costs down. You do not have to drill much if you use metal for boat flooring. This cuts down on labor involved and helps you save on costs.
Low Maintenance
If you want boat flooring material with minimal maintenance requirements, metal is a great choice. You needn’t worry about any finish for the boat. Some materials like wood must be painted, stained or given special treatment periodically to maintain the floor in good condition. This pushes your maintenance costs up. Metal is also one of the easier materials to work with when repairs and renovations become necessary. It helps to manage your boat maintenance costs.
High Resilience
Metal provides great structural strength to a boat. A solid boat floor contributes to the stability of the vessel. This increases boat safety. It gives you more confidence when you row and adds to the pleasure of the rowing experience. The high resilience of metal boat flooring helps to minimize damages to your boat.
Durable
Metal boat floors are amongst the most durable. They have a high impact resistance. Metal floors don’t easily dent or crack. They hold up well to constant contact with water. A metal boat floor will not decay, shrink or swell. This extends the longevity of your boat. It makes metal a cost-effective choice for boat flooring.
Increased Storage Area
A metal boat floor creates more room for the bilge. The bilge is the lowest part of a boat and is used as a storage compartment. The bilge storage space is useful when you have large items you wish to keep away. Water tanks, chains and other boat accessories can conveniently be stored in the bilge. This frees up space on the boat and creates a more comfortable vessel.
Adds to Boat Value
The different materials used in boat construction have an impact on the value of your vessel. A metal floor increases the functionality and durability of your boat. This is because you get more bilge storage room with a metal floor, which enables you to have a more organized vessel. Metal floors remain in good condition for several years, as they have a high resistance to wear and tear. This increases the resale value of your boat.
