Advantages of Solar Shades
- Intermediate
Solar shades are made of special materials that block sunlight and ultraviolet rays. Solar shades have several benefits as compared to conventional drapes, blinds, and other window coverings.
Keeps Heat Out in the Summer
Solar shades are typically made of a polyester weave, and sometimes with PVC coating for more durability. They're designed to block heat and sunlight, preventing them from entering your home or office and being very effective in minimizing the transfer of heat indoors. In the summer, interior space can be quite comfortable because most of the heat is blocked and glares from sunlight are also minimized.
Available in a Wide Variety of Designs
Though solar shades are somewhat pricier than regular window screens, they are definitely more economical in the long run, because of the many advantages they provide. They are also available in different sizes, shapes, and designs to suit your home or office space. Solar shades enhance the look of any living space because they are attractive and appealing.
Prevents Ill Effects of Ultraviolet Rays
Solar shades block harmful ultraviolet rays from entering your home. This way, many harmful diseases such as skin cancer and other disorders can be reduced to some extent. They’ll also greatly reduce or eliminate the deteriorations of your upholstery and carpets, hardwood floors and artwork, from discoloration and fading.
Minimizes Requirement for Air Conditioning
The use of solar shades helps in lowering the indoor temperature during hot summer days. Because minimal heat is allowed indoors during the day, the temperature indoors is also much more bearable during the night. This reduces the need for air conditioning during the summer. In the winter, heating costs can also be reduced because more heat is kept inside.
Protects Furniture and Other Equipment
Because solar shades block the direct glare from the sun and also filter out ultraviolet light, they are very beneficial in conserving items such as furniture and upholstery. Most of us have experienced the need to replace such items because of fading and other damage caused by the sun’s harsh rays. By purchasing and installing solar shades, the life span of such articles can be greatly enhanced.
Provides Clear View of the Outside
With the use of solar shades, there is no longer any need to use drapes or blinds to cover your windows. With the use of fabrics or blinds for blocking sunlight, there are several disadvantages such as blocking the view outside and fading of such materials caused by constant exposure to sunlight. With solar shades, you can enjoy the view outside without any fear of ultraviolet rays or excessive heat.
Enhance Interior Comfort
By using solar shades, you can stop bright glares from the sun that can be very irritating, especially in the morning and evening, depending on the location of your home. Direct light from the sun often hits other surfaces and reflects back, causing discomfort and harm to the eyes. It can be difficult to work or watch television under such circumstances. With solar shades, you no longer have to worry about such discomfort. All you see is a pleasant view of the outdoors that you can enjoy uninterrupted.
Conserve Energy
In the summer, because solar shades reduce the heat and glare from the sun, the indoor temperature is regulated and there is a reduced need for cooling mechanisms such as air conditioning. This is greatly beneficial to the environment because air conditioners are well known for their contribution to harmful emissions in the atmosphere.
