Advantages of Timber Cladding
40-80 hours
Advanced
- 2,500-20,000
Timber cladding is an excellent way to protect your home from the elements. Individual pieces of timber are installed over exterior walls to protect them. This helps to maintain the structural integrity of your home. It also serves as a decorative technique. In this way, it enhances the appearance of your home. Below are several advantages you can expect when you use timber for cladding your home.
Ease of Installation
The relatively lightweight nature of timber enables quick and effective installation of cladding. The installation of the timber is easier to handle and faster to complete. This helps to drive down construction costs, which makes timber a cost-effective choice for cladding purposes.
Durable
Timber cladding can last for several years when it is properly maintained. It has a high impact resistance that helps to reduce damage to your home. Scratches and chips on timber siding are not as apparent as they are on other cladding materials. Also, you can do special treatments during manufacturing in order to enhance the durability of timber, including making the timber more resistant to fire. There are also a few timber species, such as the Western red cedar and Douglas fir, that are known to last longer than most other types of wood.
Energy Efficient
Timber has high insulation properties. Its low thermal conductivity is much lower than steel and concrete. This helps to reduce energy consumption that is required to heat and cool. Also, it helps to sustain energy resources on the planet and saves you money over time.
Versatile
Timber cladding has many home designs because the wood can be trimmed to any size. Timber is also available in various patterns. You can use timber cladding on various architectural designs and their flexibility allows any scale or project. Timber also allows you to experiment with decorative effects. You can stain or paint the cladding or allow the timber to go through its own natural process of weathering for a unique and attractive color.
Environmentally Friendly
Timber is a naturally renewable resource, unlike some non-renewable construction materials. A minimal amount of non-renewable fossil fuels is required to produce timber compared to other construction materials. Timber is also 100 percent recyclable which makes it one of the most environmentally friendly materials you can use in for the construction of your home.
Acoustics
Your choice of siding can help insulate your home. There are some materials that allow noise from to filter right through the walls into the house. However, when you clad with timber it helps to filter out noises from the outside. This is because timber has excellent sound absorption properties. It helps to make your home a tranquil haven.
