8 Advantages of Using Ceramic Tile Flooring
Lead Image for 8 Advantages of Using Ceramic Tile Flooring
Ceramic tile flooring is great is a great option for high traffic areas as well as outdoor use. Consider the following perks of ceramic tile floors to determine whether they will work for you.
1 - Affordable
The affordability of ceramic tile gives you more for your money. It is not only inexpensive as compared to other types of flooring, the installation is much cheaper. It is even so easy to do that you can take on this project yourself and save even more!
2 - Waterproof
Because ceramic tile is waterproof, it works well in rooms that contain lots of moisture, like the bathroom and kitchen. It is also ideal for outdoor spaces, like a patio.
3 - Durable
Ceramic tile is very durable, making it a perfect choice for people with children playing on it and pets' claw scratches.
4 - Easy to Clean
As long as you have a good sealer on ceramic tile, it requires no special attention. Regular sweeping and mopping will be sufficient to keep it clean. If using ceramic tile outdoors, you can clean it with soap and a water hose
5 - Low Maintenance
To maintain your ceramic tile floors, you will just need to regularly clean as you would any other floor surface. Apply a sealer when the tiles start to become dull, approximately every 2 years.
6 - Variety of Decor Options
Ceramic tile options are virtually endless. No matter your decor style, there is a ceramic tile that will fit beautifully into your space, be it contemporary, Spanish or rustic. The color options are also widely varied and can be matched to any room.
7 - Easy Repairs
If you happen to drop something like a heavy flower pot on the ceramic tile floor, you may get a stress crack or damage the tile. So long as you always have a few spares on hand, you can simply remove the tile, re-grout, and seal the new tile.
8 - Mix and Match
You can create any pattern in your flooring by mixing and matching the tiles. Consider a custom design to go around the table in your dining room or living room or a standout design in the middle of your bathroom. You can use several sizes of tiles to make a one-of-a-kind design. The possibilities are only limited by your imagination.
