Aerated Compost Tea, The New Organic Fertilizer
Pouring food scraps into a compost bin
  • 1 hours
  • 0-50
Aerated compost tea is a solution made by brewing compost in aerated water.
It is highly beneficial for increasing the nutritional level and growth in plants.
Aerated compost tea has also proven useful in increasing their resistance to disease.
Preparation
The preparation of aerated compost tea is a simple process that requires an aquarium pump, a gang valve, aquarium hose, mature compost, unsulfured molasses, a straining cloth, and a bucket.
Step 1 - Choose Your Water
filling a glass with tap water
To make aerated compost tea, you need chlorine-free water. If you are using tap water, use an aquarium pump to bubble the water for a couple of hours and get rid of any chlorine.
Step 2 - Consider Air Distribution
If you want an equal distribution of air throughout the bucket, you will need a gang valve.
To install, take three pieces of aquarium hose, each piece being at least one foot long, so it can easily reach the bottom of the bucket.
Attach the hoses to the gang valve, and then place the gang valve on the edge of a five-gallon bucket.
Step 3 - Add Ingredients
hands full of compost dirt
Add one gallon of mature compost in the bucket. Make sure the compost is loose and airy.
Add the chlorine-free water in the bucket, filling to about half capacity.
The micro-organisms need a food source to grow. For this purpose, you can add about an ounce of unsulfured molasses in the bucket.
Step 4 - Aerate
Turn on the aquarium pump, and let the compost tea brew for about three days. Stir the mixture occasionally.
Step 5 - Strain
When the compost tea is ready, use a straining cloth and filter it out to another bucket.
Step 6 - Smell It
egg shells next to a bowl of dirt
An indication of good compost tea is its smell, which should be earthy and pleasant.
If the tea smells bad, it has not been prepared properly and may be harmful to your plants.
Step 7 - Apply
Apply the aerated compost tea immediately after preparation, when the micro-organisms are most active.
You can use aerated compost tea on the leaves of plants and on the soil. When applied to plant leaves, it acts as a protection against fungi and bacteria.
It also provides nutrition to the plant. When added to the soil, aerated compost tea increases the quantity of beneficial microorganisms in the soil.
These microorganisms help in the retention of nutrients, reduction in toxins, and improve the soil quality.
When applying the compost tea, never use a sprayer that may contain trace amounts of pesticides or other substances that will kill the microorganisms in the compost tea.
Benefits
Aerated compost tea is more easily absorbed by plants than compost that is mixed in the soil.
It helps in the reduction of the plant’s requirement for fungicides or other fertilizers.
The use of aerated compost tea is cost-effective, and is beneficial to the environment.
Application of aerated compost tea is safe, and it helps in a reduction in the amount of toxins we release into the ecosystem every time we use chemical pesticides or fungicides.
The aeration process ensures the tea is high in beneficial microbes, and the maximum amount of soluble nutrients is extracted.
Anaerobic tea, on the other hand, can be harmful to the plants and the soil.
