Alternatives to a Tile Backsplash
The tile backsplash is the standard in many kitchens. Although it is common, you do have some other options for your backsplash. Here are a few alternatives to the tile backsplash.
Paint
Painting a backsplash can provide you with an inexpensive way to finish the space. You can paint it in a number of different ways and mimic many different looks. This is probably the simplest way to finish the backsplash area.
Glass Blocks
Glass blocks are another method that you could use to finish the backsplash. Glass blocks are typically more expensive than tile and paint. It is also one of the more difficult jobs to install yourself, as you have to actually perform some major construction on the wall area. However, the look that glass blocks provide is very nice when you're done.
Mirrored Backsplash
Another nice option that you have is a mirrored backsplash. This type is made out of thermo-foil. This material can withstand the heat from the stove and it will not crack or break easily. This can provide a very elegant look to the backsplash space.
Plate Glass
Another option that you could utilize is plate glass. Plate glass is easy to install and it presents you with a number of different styles and colors.
