An Environmentally Friendly Paint Alternative: DIY Lime Washing
An old brick wall covered in lime wash.
  • 1-3 hours
  • 0-200
Hydrated Lime Type S
Large plastic bucket
Rubber gloves
Face protection
Safety goggles
Long pants
Long sleeves
Large plastic mixing spoon
Spray bottle
Large, rough-textured paintbrush
Rubber gloves
Face protection
Safety goggles
Long pants
Long sleeves
Spray bottle
If you don't like dealing with traditional paint, or can't tolerate traditional paint fumes, you can use a lime washing technique to make your own natural wall covering. Not only is it low in fumes, but it's also inexpensive. Perhaps the best part is by lime washing instead of using traditional paints, you will be a little bit gentler on the environment. Traditional paints have petrochemicals in them, but lime wash does not -- it's an all-natural substitute for paint.
Where to Use Lime Washing
Lime washing can be used both inside and outside your home. It’s been around for thousands of years and traditionally is used to protect the interior and exterior of buildings. At one-time lime wash was considered a poor man’s paint -- it's always been a cheap alternative to traditional paint. Now it's coming back as a “green” alternative to decorate surfaces of the home. An added bonus is that lime wash is naturally antibacterial, so it prevents the growth of mold.
Compared to traditional paint, lime wash acts more like a stain by soaking into the surface of adobe, brick, wood, and many other substrates. As the lime washed area ages, it evolves into an attractive weathered patina. For this reason, the area you're covering needs to be able to absorb the lime wash.
Beware there are some surfaces not compatible for lime, including drywall and already painted surfaces that won’t absorb it, or gypsum plasters, and asbestos cement--both are chemically incompatible. Lime wash works best on porous surfaces such as brick, cement block, terracotta, and stone. It can be used on some untreated wood, but remember since it's a very thin mixture that absorbs, it will draw out the grain of the wood.
How to Make Lime Wash
limes on a tree
There are a couple of ways you can make lime wash. You can either use Hydrated Lime Type S or lime putty. It's much easier to obtain Hydrated Lime Type S than lime putty, so that is what we use here. You can get Hydrated Lime at any hardware or home improvement store in the cement aisle.
The Materials
When making your lime wash, use a plastic bucket big enough you can make enough mixture to cover your entire surface. It's very difficult to make two or three batches that will look and adhere the same. You also want to leave enough empty space at the top of the bucket so there is no spillage. Even though lime wash is environmentally safe, it is very caustic to humans in its wet state and can cause burns. Always wear long sleeves, a dust mask, rubber gloves, and safety goggles.
There is no set recipe for making lime wash as every space, wall, and item to be painted is different. So instead of paying attention to ratios, pay attention to the consistency. Add powders to water very slowly, not the other way around (if you add the water to the powder it can create dust which should not be inhaled). Combine the powder and water with a plastic spoon or other utensil. Your bucket of limewash should have the consistency of milk. Anything thicker will not adhere well and will look more like a plaster than a lime wash. If you are unsure how much water to start with, try making a smaller batch just to see how much water and lime it takes to make a milky consistency. Then double or triple your recipe, depending on how big of an area you are painting.
Add Color
To keep things natural, there are "organic" pigments you can add to the wash to get some color. Beet juice and red or gray clay will add some color. You can even use spices like turmeric or saffron to give your mixture a yellowish-orange tint. Cinnamon gives a great brown tint.
If using a powdered pigment, mix it with hot water first in an average ratio of 20:1. Of course, the more pigment you add to the water, the deeper the color. When you have your desired shade keep in mind it will be diluted in the lime wash mixture and stir the color slowly into the lime wash.
Limewash Application
spraying water onto a brick wall
Limewash needs to be applied to a damp surface. The best way to achieve this is to spray the surface with a water mister. To apply, you can either use a large, rough-textured brush or a drywall sponge. You may need up to three or four coats to achieve your desired look. Each coat needs to dry before adding another on top, and the surface needs to be damped with a spray bottle each time. Remember to keep your rubber gloves on, especially if you are sponging the limewash on.
Let the area dry for at least three days after the final coat before touching the wall (or hanging anything on it). Limewash doesn’t look like much when it's wet, but it gets better as it dries. Drying conditions need to be favorable for it. If the humidity is too low, or the heat is too high it can cause the coat to dry too fast. Limewash needs to dry slowly.
Limewash Upkeep
There's no need to wash walls with a limewash finish -- just give them a fresh coat! It will need it anyway after about five years.
Limewashing Pros and Cons
The Pros
Lime wash is breathable, deters wood boring beetles, doesn’t peel, is a natural fungicide, is inexpensive and solvent-free, easy to freshen up. There’s no need to wash the walls - just apply a refresh coat.
The Cons
It can be difficult to match batches (so make all you need in one batch), lime wash is better in slow drying conditions (above 40 degrees, below 75 degrees, and not when the sun is hitting the area), it will need refreshed every five years, and it can leave a chalky residue that will rub off on clothing (there are additives to reduce this, but none that are environmentally-friendly).
Limewashing is a great way to "faux paint" your walls, cement or block foundations and anything else that will absorb it. It can even be used on terracotta planters. Best of all, it's not toxic to the environment!
