Bamboo Fencing: Pros and Cons
Bamboo fencing is renowned as an environmentally friendly, attractive option. Bamboo is a fast growing grass that is much stronger than timber and most types of wood. It is, therefore, an excellent option for fencing and construction. Below are some of the common pros and cons associated with bamboo fences.
Advantages of Bamboo Fences
The most significant advantage of bamboo fences is that they are environmentally friendly. Wooden fences, on the other hand, contribute to rapid deforestation. Bamboo grows back very fast. Even when bamboo is harvested, the grass grows back and as a result, bamboo forests are replenished very quickly. Using bamboo fences can slow down the deforestation and damage caused by cutting down trees for lumber. Bamboo can be harvested repeatedly, unlike a tree that is cut down once.
Bamboo is an exotic and attractive fencing option. Its natural finish is quite beautiful and it can also be stained in colors of your personal preference. When it ages, bamboo takes on a silvery sheen that is quite beautiful. There are different types of bamboo that you can select from. Construction of the fence can also be carried out in different ways, the most popular being bamboo poles strung together with twine. In warmer climates, it is even possible to build a live, growing bamboo fence.
Bamboo fences are long lasting and durable. They require minimal maintenance and care. You can achieve a naturally aesthetic and exotic look around your home by installing a bamboo fence. It is also usable in a variety of climatic conditions. It is resistant to excessive heat, ultraviolet rays, rain and snow. It will also reduce pollution because it absorbs carbon dioxide and other toxic gases.
Disadvantages of Bamboo Fences
live bamboo plants
Though it has so many great features, bamboo is not without its share of drawbacks. The first one is price. Bamboo is quite expensive as compared to other fencing options. It is even more expensive than wood and costs considerably more than vinyl or metal fences. Bamboo is not easily available in all climate conditions and therefore may have to be specially ordered. The cost of transport further hikes the cost.
Bamboo is quite susceptible to rot when not properly protected against moisture. It is vital to apply sealant and waterproof coating on bamboo before it is installed. Bamboo must also be protected against direct contact with the earth, unless it is a live fence. Bamboo has a tendency to crack and split after continuous exposure to environmental elements. If stained, the color and finish can fade off as well. It is therefore necessary to seal the bamboo fence regularly, preferably once a year.
A live bamboo fence must be kept under control with regular pruning and cutting. It can take a lot of work to keep a live bamboo fence orderly and attractive, because bamboo propagates very quickly. However, when you take proper care of it, a bamboo fence will last in good condition for many long years.
