3 Mistakes to Avoid in Basement Finishing Plans
finished basement
When making plans to finish your basement, you need to consider a number of variables. Many individuals who undertake this project end up making mistakes along the way. Here are a few important mistakes to avoid when you are getting ready to finish your basement.
Choosing Wrong Materials for Walls
One of the biggest mistakes people make is choosing the wrong materials to construct basement walls. When you are forming basement finishing plans, you may find you need to build interior walls or cover up the concrete walls around the outside of the basement. Many people make the mistake of using wood studs and regular insulation to build basement walls.
You should only use materials that will not be damaged by water. Basements tend to flood and have a lot of moisture. If you use natural materials such as wood, you are creating an environment that harbors mold. Mold can be a big problem that spreads throughout your house. Incorporate waterproof materials for the walls into your plans.
Using Hardwood or Laminate Flooring
Another mistake many people make when is installing hardwood or laminate flooring. In most cases, you should avoid installing hardwood or laminate in a basement. Both of these floors are made out of wood or have large amounts of wood in them.
If your basement floods or develops a leak, there is a good chance the flooring will be completely ruined. If you do not want to continually replace your flooring, install ceramic or porcelain tile. Consider vinyl as well. Avoid natural products like wood, bamboo, cork, or laminate.
Not Planning for Drainage
Some people forget to provide access to drainage. They install something over the top of an existing basement drain and make no provisions to access it again. When the basement floods, you need access to a drain to get rid of the excess water and dry out the basement again.
If you cannot access the drain, you may have to tear up the floor in order to allow proper drainage. At that point, you will find yourself replacing the flooring because you cannot patch it. The best option is to install the flooring around the edge of the drain. Being able to see the drain in the floor is not nearly as bad as having to deal with a flooded basement and replacing the flooring afterward.
