Ways to Brighten Your Dim Basement
lights
  • 20 hours
  • 400
Paint
Paintbrushes
Daylight colored light bulbs
Mirror panels
Paint
Paintbrushes
Mirror panels
When you remodel your basement, it can be helpful to include ideas that will help bring more light to the room. Maximizing light sources can make a basement more functional, usable, and pleasant to be in. Follow this advice on basement remodeling and helping you let in the light.
Light-Colored Paint
One of the cheapest and most effective ways to brighten your basement is to use bright, reflective paint. It will help to amplify the small amount of natural light that comes through the small windows at top of the walls.
Increase Your Wattage
Use plenty of bright lights in your basement. Daylight light color with a more bluish tone will maximize, at 5,000 to 6,500 Kelvin, will simulate natural lighting. Spotlights are another great option because they can be positioned to remove the shadows from the corners of a basement.
House of Mirrors
One option that can work in certain situations is the use of specialized mirror panels placed in the basement’s window wells. These panels have several variably positioned mirrors which are designed to reflect sunlight through the basement window and into the room below. When using this option, it is also necessary to install a protective cover over the window wells to keep dirt and other debris from getting inside them.
