How to Repair a Tilted-In Wall
2-20 hours
Intermediate
- 250-1250
The walls in the basement are very important because they keeping the rest of your house standing. If these walls bow or start to tilt inwards, then you may need to consider the basement wall repair options available to you. They aren't difficult, and if you do them properly, you can save yourself a fortune. Any damage to basement walls can call for basement wall repair techniques to quickly sure up the property. Follow these steps to repair a tilted wall.
Step 1 - Inspecting the Damage
If you suspect that your basement wall has suffered any damage, then the first thing you need to do is examine the entire problem. Rip all of the drywall from the walls and remove any other wall coverings. You need to expose the blocks of the wall so that you can see where the problem lies. Only looking at the wall itself will you be able to decide how to correct it and set it right.
Step 2 - Filling Cracks
While you have the walls exposed, take the time to fill any cracks using hydraulic cement. It will increase the strength of your overall building. Hydraulic cement is a special type of cement which expands as it dries, ensuring that it is kept firmly in place.
Step 3 - Checking for Movement
All houses and buildings settle over time, which causes them to move. This movement will create cracks and stresses on the property, which can result in tilted in walls. You will need to check whether your building is still settling by using metal plates on walls to measure the movement or a plum bob to check that everything is still level. If the house is still moving, then filling cracks won’t do any good because they will crack again when the house moves more.
Step 4 - Fixing the Wall
When it comes to fixing the wall, you have a few options. The most severe option would be to take the wall down and rebuild it; however, doing so won't be something that you want to do unless you can't avoid it. The easiest methods of fixing a bowed in wall will be using wall anchors or steel beams.
Steel beams are fitted into the wall and mortared in place. The process gives the wall more integrity and will add extra support to your house. They should also prevent the problem with your walls becoming any worse. As long as steel beams are fitted properly, you shouldn't have any problem correcting tilted in walls.
As with everything else, it's important to complete this project as quickly as possible. The longer you leave it before starting work, the more difficulty you will have fixing the bowed wall. Tilted walls need swift attention to ensure that they won't endanger your property.
