Basic Guide to Making Horse Corral Blueprints
Making horse corral blueprints is not as difficult as you think it is. Even if you are not an engineer and you have no experience setting up a horse corral before, you can work out a functional and safe to use hose corral all by yourself. To help you come up with a good blueprint for your corral, here are some tips for you.
Know the Needs of Your Horse
Before you start working on your horse corral blueprints, you need to understand the needs of your horse first. Remember that there is no such thing as a corral that fits all types of horses so make it a point to design your horse corral to fit the needs of your pet. For instance, if you have a small pony, you need not build a huge corral, but if you have a big strong mule, you need to invest in a big place and use heavy-duty corral panels that can withstand rigorous situations.
Take Exact Measurement
You cannot come up with a workable horse corral design without taking exact measurements of your available area. To measure the amount of space you have, take a measuring tape and measure the 4 corners of your available lot. If you are planning to set up more than one corral, you need to divide the amount of space that you have accordingly.
There is no hard and fast rule when it comes to the shape of your horse corrals. What is important is that your corral is big enough for your horse to be comfortable and safe inside it. To make the most of whatever available space, you can design your corral according to the shape of your land. If you have an irregularly shaped land area, you can design your corral to fit into the shape of your available area. To get some ideas as to how to design your corral, visit some of the horse corrals near you and learn a couple of tricks on how to maximize the amount of space that you have.
Put Your Designs on Paper
You need to put your design on paper before you start working on your corral. To do this, get some drawing papers, pencils and ruler then draw your blueprint to scale. When drawing your design, factor in your corners, braces, and posts. You will need at least 3 types of posts namely, the regular posts, gate posts and the corner posts. Also, you will need at least 2 braces to strength your corner posts. In your blueprint, determine the exact number of posts that you need to hold your corral together then plot down the areas where you will install these posts. As much as possible, the distances between your regular posts should be even. When it comes to the height of your fences, you should aim for at least 4 feet high fences to contain a mustang or a stallion.
Determine the Kind of Materials You Need
In your blueprint, you should already identify the kind of materials that you should use for your project. For instance, you can use a combination of posts and rails or post and wires for your horse corral.
