Bathroom Laminate Flooring: Advantages and Disadvantages
Bathroom laminate flooring may be a good option for your home. Read on to learn about the pros and cons.
Price
Laminate flooring is a much more affordable choice for a bathroom than other materials, such as wood or even tile. You can usually purchase laminate flooring for as low as $1.50 per square foot. Traditional hardwood flooring can cost 3 to 4 times as much.
Installation
Laminate flooring can be placed on any type of surface, making installation quick and easy. Most of the time, you can use a simple adhesive or glue to secure the flooring.
Lifetime
Laminate flooring is ideal for areas that see a lot of traffic. It doesn’t show wear as quickly as hardwood does, and cleaning is much easier. While hardwood requires oil and frequent cleaning by hand, laminate just needs a broom and a mop. It’s hard to damage laminate flooring, which makes it good for households with small children or pets. A laminate floor won’t show scuffs and scratches. You won’t need to worry about buffing it out every few years.
Designs
While laminate flooring is available in a wide variety of design options, many brands manufacture styles that simulate other materials, such as wood and stone. You are limited by what stores carry. Hardwood flooring, on the other hand, can be customized. You can choose the wood type, color, stain, and grain. You can also change its look after installation through sanding and staining. With laminate, you are stuck with what you have, and new home décor may mean the entire floor needs to be replaced.
Moisture
Laminate flooring is naturally moisture-proof, but it offers little protection for the flooring underneath. The adhesive used can also be affected by moisture causing the flooring to warp or pop. Experts may suggest using a different type of flooring in a bathroom.
Sound
To some people, the sound created from walking on a laminate floor can be a nuisance. It makes a hollow sound, or can sound sticky if installed with air bubbles underneath. If this is a problem for you, consider adding an acoustic underlay. Doing so will reduce awkward hollowness of laminate. Hardwood floors won’t have this hollow sound.
Resale Value
You will see a greater resale value in a home with laminate flooring, but remember that people will know it’s not real hardwood. Having traditional hardwood will increase the value of the home even more.
Find Trusted Professionals For Your Bathrooms
