Benefits of Composite Decking
While traditional lumber holds up great against the elements, it also comes with a lot of work - sanding, cleaning, staining, and sealing. Composite decking, on the other hand, offers the same level of protection without the annual upkeep. With many homeowners beginning to explore alternatives to traditional deck materials, what are some the benefits of choosing composite decking?
Maintenance
Composite decking performs well against all types of weather conditions. Not only will it stand the test of time, but it needs very little maintenance to keep up its original look. With composite decking, you do not have to paint, stain, or seal it. These composite materials are also resistant to warping, rotting, weathering, and other problems associated with regular wood decks.
Safety
While lumber always comes with the threat of a splinter or two, composite decking is completely smooth. Not only can your children walk bare foot without the fear of splinters, but composite decking is also very slip-resistant, making it a great option for children and pets alike.
Performance
If not maintained on a yearly basis, lumber decks can quickly deteriorate, especially after cold winters, hot summers, and rainy springs. Fortunately, not only do composite materials hold up great against a range of temperatures and seasons, but they do not fade or warp as a result of hostile conditions. With composite decking, you can rest assured that your deck with have a long life without all the hassle of traditional lumber.
Eco-friendly
Composite decking is created by combining wood or cellulose fiber with plastic. The wood used in the process is often taken from recycled wood pieces, making composite decking a great option for the environmentally conscious homeowner.
Cost
When it comes to building costs, most people will be surprised to learn that composite decks are actually cheaper to build over the long run. Although they are often a little pricier at the start, composite materials cost less when maintenance and durability is factored in. If you choose to go with pressure treated lumber, you will actually pay more in maintenance fees and still have to replace the deck in about 10 years.
Pest Free
When it comes to standard wood materials, homeowners are often faced with fighting off bugs. Without properly infused wood, these pests can result in wood rot, mold, unwanted growths, and other negative outcomes. Composite decking, however, is resistant to bugs and will not mold or decay over time.
Long Lifespan
Speaking of durability, composite decking has a much longer lifespan than traditional lumber decks. While a regular wood deck will be up for a replacement in about 10 years, composite decking can last much longer - some warranties allow up to 25 years - because of its composition and ability to withstand weather conditions.
Value
Along with adding less maintenance to your life, composite decks actually increase your home’s value. In fact, most homeowners get back the money the put into composite decks after they sell. Not only does this mean that composite decking is cheaper to build over its lifespan, but you can also reap the rewards if you ever choose to sell your home.
Design
Like pressure treated lumber, composite decking allows a homeowner the flexibility to design a deck that fits every need. Composite materials come in a variety of colors and shapes that are suitable for just about any outdoor decor. Anything you can create using traditional lumber can be replicated with composite materials, even faux wood grains or tiles.
Railings
In regards to flexibility in design, composite decking can be used for other design features as well. The railing of a deck often comes with even greater challenges in upkeep, especially when it comes to caps, posts and balusters. While homeowners struggle keeping wood boards in top shape, composite decking can be used to create railings and balusters without the added hassle. Although they cost more than regular wood, these pieces only require an occasional cleaning to keep in top shape.
