Benefits of Installing Vinyl Flooring
Vinyl tiles can make an attractive addition to your floor. A special type of plastic or polyvinylchloride (PVC) is used to produce the tiles. Vinyl is often used as a substitute for leather. It is also referred to as faux leather. With the various options of flooring material available on the market, one may wonder which is best. Below are some of the key benefits that come with a vinyl floor.
Ease of Installation
The self-adhesive backing on most vinyl floor tiles makes it easy to install. You simply peel off the backing and attach the tiles to the floor. No specialized skills or tools are required. Installation can be completed much faster than other floors. It helps to keep your construction costs down.
Low-Maintenance
Vinyl floors have minimal maintenance needs. Simply sweep the floor when dirty. You can mop once a week or as the need arises. Vinyl is water and stain-resistant which contributes to its low-maintenance nature.
Moisture Resistant
Vinyl has a high resistance to water. This makes it suitable for use in the kitchen and bathroom. The water-resistant nature of vinyl also adds to its durability. Flooring materials that have low water-resistance do not last as long as vinyl. Repairs and replacements ultimately add to home maintenance costs. The impervious nature of vinyl floors spares you from the common problems of mold and mildew that develop under floors.
Affordable
Vinyl flooring is relatively inexpensive. Yet it offers one of the greatest selections in styles and designs. Flooring can take up a considerable portion during home construction, especially for large floor spaces. With an option like vinyl, you can complete your home project on schedule without budget restrictions. Should you desire a change, the affordability and ease of installation makes it easy to accomplish. It makes a cost-effective choice.
Design Flexibility
Vinyl flooring gives you a virtually unlimited variety in design and styles. Tiles are available in various sizes, colors, textures, and patterns. Vinyl flooring can be customized. Varieties that resemble expensive flooring such as marble or intricate wood designs can be produced. Texture is also created to match a particular floor type. This enables homeowners to achieve whatever style they prefer. Vinyl also blends well with various décors. Where the budget cannot allow a certain floor, vinyl can prove to be a suitable substitute.
Comfortable
The soft feel of a vinyl floor adds to room comfort. Yet it provides great support for the feet. The floor doesn’t feel as cold as some other flooring materials can be. Noise generated from vinyl floors is minimal.
Durable
Vinyl flooring is one of the widely recognized resilient flooring types. It can withstand heavy use and foot traffic over long periods, yet remain in good shape. The moisture and stain resistant properties add to its durability. Water and stains often contribute to high wear and tear of flooring. When properly installed and well maintained, a vinyl floor can last several years.
