Boat Hull Cleaning Tips
Boat hulls are subjected to heavy abuse making the boat hull cleaning process difficult. Boats are exposed to polluted water, and extreme weather conditions that lead to corrosion. Thus, the boat hull needs to be regularly cleaned and maintained. This will not only ensure the boat hull is shiny and smooth but also ensure the boat moves faster through the water. if you don’t want to spend hundreds of dollars on hiring a professional, consider doing it at home. Follow these simple tips for cleaning the boat hull.
Using Low Power Hose
Use a low power hose to rinse the boat hull. This will help get rid of salt build up. It will also help remove mold or algae that may have gotten stuck to the boat hull.
Use a Chemical Cleaning Solution
Use a boat hull specific cleaning solution to clean the boat hull. Ensure extreme care is taken when using the solution and that you have thoroughly read through the manufacturer’s directions.
Using the Right Sponge
Use a large soft sponge to clean the surface. Apply the cleaning solution and use it to scrub the boat hull surface. Move the sponge gently in circular patterns.
Using Muratic Acid
Use muratic acid or an acid-based cleaner for tough and extensive cleaning of the boat hull. The muratic acid requires at least 10 to 15 minutes to work. Once applied, the acid must be brushed using a soft bristle brush. This is ideal for extremely dirty and algae covered boat hulls.
