Brick and Stone Combinations
Using brick and stone in buildings has a long tradition, and there are a number of ways in which you can place a brick and stone combination in your own home. There are many varieties of bricks and stones, and so if you choose to install these materials in your home, you need to organize the different types in order to get the best appearance for your home or garden. When considering what building materials you will need in your wall, path, or patio, then you should choose types of brick and stone that compliment each other.
Brick and Flagstone
Flagstones are a very traditional form of building material, and combining these with clay bricks will help you to give your home a classical feature. Clay bricks are rough and irregularly sided, which means that they look more like the hand-fired bricks of old. They make great accompaniments to a restoration, or to a home built in the "Olde World" style. Flagstones can be made out of many different types of stones, but if you are installing a clay brick, you might consider comparing it with a limestone or fieldstone tile, as these will also add a traditional charm to a room or garden.
Red Brick and Slate
Slate is an excellent stone for use in paving, or as features in a wall. Traditional slate stone is grey or black, and you can combine this with a bright red brick which will create an interesting contrast. Slate is a rather soft stone, so you may need to use it more sparingly than others, but it does look very appealing.
Brick and Marble
Marble is perhaps the most awkward of the stones to fit with a brick design, as it can clash with traditional red brick. You may be more successful with a darker brick, which will help you to flatter the stone. Marble is also not suitable for large areas, and instead should be used to fill in small gaps in the wall, with larger bricks used for the surround.
Faux Brick and Stone Finishing
If you want to install a brick and stone feature in a home, or perhaps wish to complete a renovation using brick and stone, you may prefer to use large blocks and then cover the edge with a faux stone and brick finishing. This finishing can be an excellent and cost-effective alternative to the difficulty of building a brick and stone home.
Using Brick and Stone
However you use brick and stone combinations, it is probably best to use the brick, as this can be cheaper and easier to install. Stone can be an interesting feature, but should not be over-used. Laying stones in lines, rather than using large blocks will make them easier to manage, and can also provide a traditional feeling to a room. If you're intending to use a stone and brick combination on a wall, you may not need to cover the entire area with a mix of the two, but should attempt to use all of the material that you have purchased.
