Brick Home Vs. Brick Veneer Home
A brick veneer home is one that is constructed from a metal or wood frame that is covered with a single brick layer on the exterior. A brick home, on the other hand, is constructed of two layers of brick or an inner layer of concrete blocks covered by an exterior layer of brick. Both these styles of construction have their pros and cons. However, brick veneer homes have been rising in popularity and are more widely used in construction in the past few decades.
Advantages of a Brick Veneer Home
A brick veneer home looks identical to a solid brick home, but it is vastly different in its method of construction. The main frame of the house itself is constructed of wood or a metal such as steel. This frame is then covered by some form of insulation in most cases. The final outer cover is composed of brick and mortar. This outer brick layer does not support the house in any way and is connected to the inner framing by means of metal straps affixed by screws.
Some of the main advantages of a brick veneer home include affordability, ease of construction and better insulation. Because the construction process only involves a single outer layer of bricks, the process is quicker and much less laborious. This enables cost savings in material and also installation fees, thereby making the structure more affordable than a solid brick home.
The space between the inner framing of the house and the outer brick layer acts as an insulating area. This insulation is even better when the space is filled with insulating foam or a similar material. Also, brick veneer homes tend to be much lighter and do not require as much structural support as a brick home.
Drawbacks of a Brick Veneer Home
A brick veneer home does not provide the same structural strength as a brick home. It may therefore be subject to damage from heavy winds, tornadoes, hurricanes or earthquakes. Also, if the inner framing is wood, the home may be subject to damage from insects and termites.
Advantages of a Brick Home
A brick home, when properly constructed and maintained, can last for hundreds of years. It is much more stable and secure in the event of natural disasters. It is also more resistant to rot, rust or termites because the structure is entirely made of brick.
Disadvantages of a Brick Home
On the downside, a brick home is more expensive and cumbersome to build. It is also more prone to water damage as compared to a brick veneer home. This is because brick does not resist water very well and in the event of heavy rainfall, water can seep to the interior of the home. The absence of an insulating material also reduces the energy efficiency of the structure.
Brick veneer homes are rising in popularity because they offer good structural strength and better insulation at a lower price.
