Brick vs Concrete Block Pavers
Block pavers are one of most popular materials used to beautify patio surfaces. Patio pavers give your home a distinct look. When well-installed and maintained, it adds considerably to the value of your home. With various materials to choose from, selection may be somewhat of a challenge. You want to be sure that the material used will last several years. Some of the more widely used patio paving materials are flagstone, blocks and tiles. Blocks may be made of brick on concrete. Below are the pros and cons of each.
Advantages of Brick Block Pavers
Installation of brick pavers is less technical than concrete entails. Little equipment is needed to produce an attractive brick paved patio. This gives you significant savings on costs. Once installed, a brick patio doesn’t require much to keep it in good condition. It will also retain its uniquely traditional look for several years. Maintenance costs for brick pavers rate lower than concrete. The patio should be washed whenever necessary. You needn’t clean a brick paved patio as often as the concrete-type requires. A sealing job can be done every couple of years to maintain in good condition. With brick pavers you needn’t be concerned about color fading. Bricks reflect a natural color that occurs uniformly throughout the brick.
Disadvantages of Brick Block Pavers
Brick pavers cost more than concrete. This may be a deterrent to installation especially if you’re on a moderate budget. Color range is restricted with brick pavers. Available colors for brick occur naturally. If you’re keen on achieving a unique color or range of colors, brick is unlikely to work for you. Bricks are known to crack or break often, especially if patio usage is heavy. You’ll be compelled to replace individual bricks to maintain the uniformity of the patio surface. If replacements are ignored, your patio will not look as good as when first installed.
Advantages of Concrete Block Pavers
Concrete pavers are cheaper than the brick variety. The raw materials used to manufacture concrete pavers costs much less than material used for brick. This contributes to the lower cost. With concrete pavers, you are virtually unlimited in design, style and color unlike brick. When well-maintained, concrete pavers can last several years.
Disadvantages of Concrete Block Pavers
Installation of concrete pavers involves some level of expertise and specialized tools. You may have to call in a professional to do the job. This adds to your overall costs. Maintenance costs are higher for concrete pavers. This is part due to the color aspects of a concrete patio. Most concrete patios bear a specific color or range of colors. To maintain the color shades and avoid streaks or fading, you’ll have to seal regularly. While brick pavers can be left longer before general cleaning, concrete requires more frequent cleaning. When a concrete paved patio isn’t cleaned often it detracts much from the appearance of the home. Should you relax in maintenance procedures, your concrete pavers are unlikely to look attractive a few years down the line.
