How to Build a Shower Stall in 10 Steps
6-12 hours
Intermediate
- 350-1,000
You can build a shower stall in a few steps if you have the right tools and the necessary knowledge. Here's a quick guide to building a shower stall.
Step 1 - Select Style
Choose the style of shower stall that you want. Pick a style that works well with the space that you have. If you have a large bathroom, you might consider installing a shower stall intended for two people.
Step 2 - Consult Plumber
Nothing dictates that you cannot do the plumbing yourself when installing a shower, but be prepared to consult a plumber with questions. The better prepared you are, the better the process will go.
Step 3 - Prepare Area
Prepare the area by installing needed flooring material or doing anything else that needs to be done before the new shower stall is installed. If you do this all beforehand, it will help greatly.
Step 4 - Read Instructions
This is a vitally important step because knowing what steps need to be taken will ensure that you properly install your shower stall.
Step 5 - Begin Installation
Begin by installing the shower pan, putting it on the subfloor or concrete over the drain with a shower adhesive. Install the first panel using shower adhesive on all sides and corners of the non-shiny side.
Step 6 - Measure Mixing Valve
Measure the mixing valve's center to guide you in drilling holes for the shower fixtures.
Step 7 - Install Remaining Panels
Install the shower panel where the fixtures will insert, the same way that the first panel was installed. Then install the remaining panels.
Step 8 - Install Plates
Install the base plates that will accommodate the glass enclosure, using blue tape to hold them together while you drill the holes and secure everything into its place.
Step 9 - Finish It Off
Place the side plates and the glass panel enclosures. Add rubber piping to ensure that the entire enclosure is completely watertight. Finish off the top by adding the top plates to the shower stall. Use silicone caulk to keep the glass seams completely water-tight.
Step 10 - Install Fixtures
Add the shower fixtures, including control knobs and showerhead, as soon as all of the caulking and adhesives have been set up completely. Prevent leaks with plumber's tape on the showerhead. Make sure that there are no leaks before using your newly installed shower stall.
