Build a Ventless Fireplace for Additional Heat
A ventless fireplace can be an effective way to add extra heat to your home. However, store-bought fireplaces are usually quite expensive. Building your own ventless fireplace can save you a great deal of money and your fireplace will work just as well as any purchased fireplaces. It is not complicated to build a ventless fireplace yourself.
Mantels
A complete ventless fireplace does not require a mantel. However, a mantel can add a great deal of charm and appeal to a fireplace. Mantels are sold in a variety of forms and can be highly decorative.
Facts and Features
The actual construction of a fireplace requires a significant amount of before-hand planning. If you spend time deciding what you want and how you want to go about achieving it, you will have much better results than if you just charge into the construction process. You can find a wide range of fireplace designs on the Internet. Many websites provide step-by-step instructions for building a ventless fireplace. You can also find information at your local home improvement store.
Planning and Designing
Ensuring that you have all of the necessary materials and building diagrams before you start building will make it much easier to build your fireplace. You won’t have to worry about having to stop in the middle of the project in order to go get more materials.
Build Your Fireplace
The first thing that you need to build is a hearth. The hearth goes under the mantel and will be the foundation for your new fireplace. There are many ways to design a hearth. The hearth’s design is partially a matter of personal preference. You can add decorations to the hearth and use whatever materials suit your design choice. Many people prefer to make their fireplace flow with the room as much as possible so that it appears that the hearth has been a part of the house since the house was built.
After you have designed your hearth, you will create a fireplace insert that has a screen. You can choose to buy an insert or try your hand at creating your own. Whatever your decision is, the most important thing is to make sure that the insert is installed according to regulations. The last thing you want is to install a fireplace and then have your house catch fire.
Professional Inspection
Once you have everything in place, it is a good idea to have a professional inspect the fireplace. This will ensure that everything has been installed properly and that there are no problems.
