Build a Wardrobe Closet for More Storage
For more storage you might want to look into build a wardrobe closet. A wardrobe closet helps you not only have more storage, but gives you a place to keep your clothes organized.
Frame the Walls In
Once you know where you want to place the wardrobe closet, you will have to begin by framing in the walls. 2x4 studs are the most common materials used for framing and are placed 16 inches on center. You can build the walls on the floor, or if you using an existing area, just build the frame on the wall.
Add Shelves and Cabinets
After the frame has been built, either by scratch framing (framed on the ground and lifted into place) or by building directly onto existing walls, it is time to add the shelves and cabinets. Plywood, or other types of hardwood can be used here.
Add Walls and Trim
If there are exposed areas of your wardrobe closet then you will be closing them in with wallboard or drywall. Cut the drywall to size and hang to the exposed 2x4 studs. Tape and mud compound the cracks and screw holes, sand, and then paint. Add trim to the top and bottom for a finished touch.
Finish Inside, Door
Depending on what you want on the inside of the closet, paint or stain the shelves and cabinets. Add a folding or sliding door and you are done with your wardrobe closet.
Measure Depth First
This is the measurement that can throw off the entire walk in closet. If you are installing a walk in closet system, or building one from scratch, the depth of your closet must be carefully measured. Take this measurement in two ways. First, set a tape measure on the floor and measure front to back. Next, put the tape measure about should high and do the same thing. Hopefully the measurements are the same. If not, you will have to work with shimming the back for a good, tight fit.
Measure The Height
Three places in your walk in closet dimensions should be taken for height. Start at the front of the walk in closet and measure from top to bottom. Move to the center of the room and do the same thing. The go to the back of the closet and to either corner to take the measurement. Again, the measurements should be the same. If not, then not the difference in case you have to level out rods and shelves.
Measure The Width
The last walk in closet dimension is the width of the closet. From side to side you should measure in the front, in the center, and in the back of the closet. This doesn't have much impact on the overall system, but you should make sure this measurement is accurate.
