Can Reflective Roof Paint Save You Money?
Everyone's looking to save money, especially when it comes to energy costs. If you live in a hot, sunny region, it could be worth the time and energy to look into painting your roof with reflective paint.
How Reflective Roof Paint Can Save You Money
There are several ways that reflective roof paint can save you money, as detailed below.
Easily Fix Small Leaks
Water and precipitation are some of the largest threats to your roof, and if you’re experiencing small leaks here and there, you likely don’t want to completely replace your roof. This can be a costly venture that’s quite time-consuming.
However, a coating could be a great alternative to re-roofing. This could save you a lot of money and help keep the inside of your home dry and leak-free.
On average, adding a reflective coating to your roof costs about half the price of a full re-roofing. The process is less invasive and allows you to comfortably stay in your home while the coating is occurring.
The process does not require the roof to be removed, causes minimal disruption, and has fewer labor costs associated with it.
Extend the Life of Your Roof
Adding a reflective coat can extend the life of your roof on average by five to seven years. This allows you to save your money for an eventual full replacement without worry.
Lower Your Utility Bills
No one likes paying an arm and a leg for their utility bills. One way to lower yours is to use reflective roof paint on your home. Since the majority of roof materials are dark in color, that means that they naturally absorb the heat of the sun.
This heat is transferred to the inside of your home, causing you the need to use your air conditioning more to keep your space at a comfortable temperature. However, a reflective coating keeps light and heat away from your roof, meaning that the inside of your home will be cooler.
Thus, your energy bills will decrease, without you sacrificing your own comfort during the heat of the summer. Plus, this is good for the planet, so it’s a win-win!
Heat Your Home with Less Energy
Just as your reflective coating can help you keep your home cool more easily during hot weather, it can also be of assistance during cold weather. This is because it can assist in keeping heat inside on colder days.
This happens due to the fact that the heat that reflective paint absorbs will act as an insulator for your home. If you live in an area with a long winter or that’s particularly cold, you can even look into reflective paint that is known to be better at insulating in order to take advantage of this property to its fullest potential.
Tax Credit Incentive
Replacing your roof fully doesn’t merit a tax credit, but now, you can receive a federal tax credit for using reflective paint. Recent tax changes dictate that you can receive a ten percent credit on the cost of your roof if you use a coating surface on it.
This is a huge saving for many families. Be sure to check the Energy Star website for guidelines on this and to learn more about receiving a tax credit with this helpful addition to your home.
A Wise Investment
The reflective coating comes at a fraction of the cost that a full roof replacement does. After one coat is performed, it can last up to 15 years, which is a staggering lifespan for all of these benefits and savings.
Between helping you save money and assisting in environmental efforts, a coat of reflective roof paint can do a lot of good for your home and your wallet. This is definitely something to consider as you update your home, inside and out!
