Car Radio Repair: Troubleshooting the Wiring
  • 1-2 hours
  • 25-125
Screwdriver
Fuses
Noise filter (optional)
Screwdriver
Fuses
One of the most important aspects of a car for many people is the radio and knowledge of car radio repair is a necessity. There are even some people that spend more money on their car’s radio than the overall worth of the automobile. For those people, the car’s radio must be working at all times and is used even when they are not driving the car. When something goes wrong with the radio, there is a complete sense of urgency. There are a few things that you can keep in mind when it is time to take a look at the wiring of your stereo system in your car.
Step One: Check the Antennae
One of the major components of your car’s stereo system is the antennae. It is also one of the most overlooked aspects of your car stereo. There are many times when the antennae can become moved from its original position or can become unwired. The wiring of the antennae is one of the most common causes of car stereo malfunction. The easiest way to check your car’s radio antennae is to unscrew the plate that holds it in place. If there are no screws, the antennae itself may unscrew. If the wiring looks as if it may be faulty, you should replace it. Even if the wiring looks okay, it could be damaged farther down into the channel.
Step Two: Fuses
Your radio will hold many different fuses depending on the quality. Some of these fuses can eventually wear out or can be blown for a number of reasons. One of the main reasons for blown fuses are crossed wires. You may want to pull out the radio from the console and make sure that there are no wires that are touching one another and there is one leading to the left speaker, and one leading to the right. Ensuring that your wiring is correct can not only solve immediate problems but may prevent problems from arising in the future.
Step Three: Amplify
One great way to improve the performance of your radio is to add an amplifier. An amplifier can supply your radio or car stereo with that extra boost you are looking for. Before installing an amplifier, make sure that your stereo and speakers can handle more output. If not, you will end up with blown speakers that will sound worse than your stereo before installing the amplifier. There are many choices available to the consumer when considering the purchase of an amplifier, and with a little research you can figure out the right one to meet your needs.
Step Four: Noise Filters
For a better quality sound out of your car’s stereo, you may consider installing an noise filter to clean up the output. Many times older car stereos will begin exhibiting noises such as distortion or muffled noises. By installing a noise filter, you will clean up this sound and will have much better quality sound running through your speakers.
Step 1: Check the Antennae
Step 2: Fuses
Step 3: Amplify
Step 4: Noise Filters
For a better quality sound out of your car’s stereo, you may consider installing a noise filter to clean up the output. Many times older car stereos will begin exhibiting noises such as distortion or muffled noises. By installing a noise filter, you will clean up this sound and will have much better quality sound running through your speakers.
