Carpet Cleaning Machines 101
Carpet cleaning machines for do-it-yourselfers are designed to help individuals remove stains and dirt from and restore the appearance of their rugs. These machines range in style and purpose with some more suited for certain jobs than others.
Upright Extractors
These are by far the most common carpet cleaning machines for home use. They involve the use of a clean water reservoir and a gray water reservoir. Clean water and soap are sprayed onto the carpet and then the soiled water is sucked back into the machine.
Steam Machines
Carpet cleaning machines that profess to be steam models for home use generally do not operate at quite the right temperature to produce steam. Instead, they rely on the use of hot water to help loosen and lift dirt and debris.
Hand-held Devices
This type of carpet cleaning machine is a portable version of a larger model.
Function
Home-use carpet cleaning machines might not always give professional results, but they can greatly improve the appearance of carpeting. They are most commonly used for routine cleaning and spot cleaning. Carpet cleaning machines that are upright or canister in nature are generally designed to clean large surface areas. Handheld and even full-sized carpet cleaning machines can be very useful for removing stains before they set in.
