Cedar Hot Tub Pros and Cons
1 hours
Beginner
- 1
When it comes to weighing the advantages and disadvantages of a cedar hot tub, the pros outweigh the cons. Cedar is a great material for building hot tubs, and you will be able to find the right size and design for you. Keep reading to learn about the pros and cons of hot tubs made out of cedar.
Affordable
Cedar hot tubs, compared to common hot tubs made of materials such as acrylic or fiberglass, tend to be sold at much cheaper prices. Even if the hot tubs both had the exact same features, the cedar hot tub would be cheaper.
Durable
Cedar is a material that works very well with water. When water is in contact with the wood, it remains just as durable as it was when it was dry. This is an uncommon characteristic of most types of wood. The cedar will actually expand with so much contact with water. This is a perfect characteristic for hot tub material since one of the most important elements of them is the ability to hold in water completely. The expansion will close up and tighten any points that water might otherwise have seeped its way through.
Difficult to Clean
The major disadvantage of having a cedar hot tub is the fact that it is so hard to clean. With an acrylic or fiberglass hot tub, you can easily and clearly clean the surfaces of the tub. Many cedar hot tubs actually feature fiberglass or acrylic within the actual tub, making the cleanup a cinch. Woods, on the other hand, will be harder to clean when it comes time to do so.
Avoids Mold
Another advantage of cedar hot tubs is the fact that the material naturally avoids mold. This characteristic of cedar is one of its biggest selling points as a material for hot tubs. Because the wood is harder to clean than synthetic material, avoiding mold should be a top priority.
Beautiful
One of the reasons people purchase cedar hot tubs over others is the visual addition it brings to their yard. The cedar will keep its elegant look for many years, even outdoors. Cedar is known for withstanding trouble such as bad weather, proving its durability even in rough times.
Aromatic
Another great reason to go with a cedar hot tub is the amazing aromas it releases when filled up with steaming, hot water. Not only will the warm bubbles and massaging jets relax you, but the smell of cedar will enhance the experience even more. Synthetic materials, however, will give off only a chemical sort of smell.
Bug Repellent
On top of all the amazing advantages, cedar hot tubs have, they also repel common bugs such as moths. As a natural deterrent, a cedar hot tub allows you to keep the bug spray in the house so to speak.
