Cedar Shingle Siding
Lead Image for Cedar Shingle Siding
  • 20-40 hours
  • 1,200-3,500
Cedar shingle siding differs from cedar shake siding used in home renovations and new construction projects. The cut of standard cedar shingle siding is not as thick as the cut of a cedar shake siding. It is a form of wood siding that is used in more expensive types of new home constructions or in renovation projections to restore an existing cedar shingle sided home.
The Cost of Cedar Shingle Siding
Cedar shingle siding can run at prices of $8.00 per 1 inch by 6-inch section and upwards, depending on the type of construction or building use. Cedar shingle siding is often found in more expensive new home construction for houses costing $500,000 or more. The use of this material provides a distinctive look in some communities that differs from homes built with vinyl siding.
Choosing Cedar Shingle Siding
Choosing to use cedar shingle siding in your renovation project or new home construction should be based on the aesthetics that you are looking to achieve and the overall look of the home. Cedar shingle siding provides a good alternative to the thicker shake style shingles.
