Choosing Sizes and Steps for Spiral Staircases
Tape measure
Power saw
Spiral staircase kit, or
Pre-assembled spiral staircase, or
Custom design spiral staircase
Spiral staircases are considered a fashion statement, especially nowadays when such fancy architectural designs are in vogue. For children, they add a touch of adventure to a home while saving space and money They are easier on the pocket than regular staircases. You will be amazed at the variety of shapes and sizes available. Choosing a spiral staircase is no easy matter; follow these guidelines when considering a spiral staircase for your home.
Step 1 - Assess Location
You will have to decide where exactly you plan on putting up a spiral staircase. Depending on whether you want the staircase to be indoors or outdoors, you will have to choose a model designed for that purpose Once that is confirmed, you will have to pick the material of the staircase. Material options include wood, metal, or a blend of the two.
Step 2 - Measure the Area
Wherever your spiral staircase is going to be placed, you need exact measurements from the floor to the ceiling, as well as the diameter of the staircase. If a staircase is to be placed under an opening directly to a floor or ceiling above it, then it should be a 3 or 4-inches narrower than the opening for a better fit.
Step 3 - Get a Ready-Made Staircase Kit
You can choose a staircase kit that you like from a dealer that sells them. These kits are shipped in an unassembled form and are available with complete assembly instructions. The only things you will need are the basic hand or power tools, along with some helpers when you are ready to install the staircase.
Step 4 - Spiral Staircase Plans
If you are confident that you can build a spiral staircase from scratch yourself, you don’t need lots of fancy equipment. In fact, all you need is a good wood planer and a table saw. Such a project is manageable, providing you have strong clamps and a good set of spiral staircase plans.
Whether you build a staircase from plans, assembly kit, or purchase a ready-made spiral staircase, you have to make sure you meet the building codes of the area in which you live. Every location has different building codes, so make sure you know what the requirements are.
Step 5 - Consider Custom-Made Spiral Staircases
You can also have a spiral staircase made especially for you. Doing so is costly because it is made to order and you can choose from a variety of spiral staircases. If money is not a factor, a custom design is the best option. You can collect a few pictures or sketch your ideas and leave the implementation to the experts. The dealer will give you an estimate of cost and time for assembly.
Step 6 - Search for Dealers Online
Make sure you choose dealers that have a good reputation. Check with Better Business Online and select a few companies. Study their websites. Have all of your queries ready along with the measurements. Also inquire about any extra costs, like shipping rates.
