Choosing the Best Basement Ceiling Insulation
One of the main concerns when undertaking a basement ceiling insulation project is choosing which type of basement ceiling insulation is best suited for your basement. Since saving on costs without compromising on quality is everyone’s prerogative and there is a limitless range of ceiling insulation types available, it becomes hard to remain objective and make the right choice.
Shopping from catalogs or in stores without prior knowledge of the pros and cons of each type of ceiling insulation can be an overwhelming experience. People often end up getting confused and either choose poorly or overspend.
Different Types of Basement Ceiling Insulation
There is a wide array of basement ceiling insulation available on the market these days. Each of them is specially suited to certain types of basements, budgets, and functions.
Blanket Basement Ceiling Insulation
Blanket basement ceiling insulation comes in either rolls or bats. It is often purchased simply because it is inexpensive. When working on a budget in a large area, this insulation is undoubtedly the most popular. It is the easiest to install while being light on the pocket. Cotton blankets or fiberglass blanket sheets are an example of this kind of basement ceiling insulation. The disadvantage of this kind of insulation is that it provides only a limited degree of control of thermal transfer.
Concrete Block Ceiling Insulation
Concrete block ceiling insulation is ideal for newly constructed buildings and structures.
Foam Board Ceiling Insulation
Foam board ceiling insulation is slightly steeper in terms of price, but it provides a greater degree of insulation.
Loose Fill Ceiling Insulation
Loose fill ceiling insulation is shredded newspapers and tightly packed pieces of other loose materials which make for an excellent insulation layer. It can be more expensive, but it is very effective.
Sprayed Foam Basement Ceiling Insulation
Sprayed foam basement ceiling insulation is the most expensive. It is best suited for basements that require no other work and are completely ready. It provides the greatest degree of insulation, even in tiny spaces and hard to reach spots.
Choosing the Kind of Insulation to Use
The final choice of which kind of ceiling insulation to install in the basement is dependent on a number of individual factors which come together to determine the strength of the choice. The following considerations have to be considered when selecting ceiling insulation.
Budget
The cost of the material as well as the cost of installing it must be considered. One should consider the initial expenses in terms of the long term energy savings and make a choice accordingly. For those working on a budget, fiberglass sheets are the best option, but if one has money to spare, sprayed foam is the most long lasting and effective choice.
Space Available
Insulation reduces the height of the basement. It is important because of local building codes and regulations without creating a cramped or clustered room.
Local Weather Conditions
Climate has a significant impact on the insulation used. One should pick a material that can withstand the local climate.
