Clean and Polish Sterling Silver: Toothpaste vs Baking Soda
You can have one of the most appealing and well known metals in your possession if you regularly polish sterling silver wares. But since silver is a naturally soft metal and can be easily bent out of shape, it is usually made into various sizes and shapes in combination with another metal which is typically copper. This combination is called sterling silver, which has increased strength but is prone to tarnishing. This is due to the reactive nature of copper. To keep sterling silver sparkling all the time, different methods of cleaning sterling silver were devised, but two of the most popular are with the use of baking soda or toothpaste.
Baking Soda Cleaning
If baking soda is chosen for cleaning silver, it is mixed with water to form a paste. It is rubbed on the silverware and then rinsed off. A soft cloth is then use in polishing it dry.
Toothpaste Cleaning
If toothpaste will be used on the other hand, the sterling silver is coated with it and the silverware is consequently run in warm water. The toothpaste is worked into foam and then rinsed off, just like with brushing your teeth. If there are intricate designs in the silverware or stubborn stains are present, a soft bristled toothbrush might be used.
