Cleaning Carpet Stains the Green Way
If your carpet has been stricken with troublesome stains and you're put off by the plethora of potent chemicals found in most commercial cleaners, you many be looking for an effective method of cleaning carpet stains the green way. If so, you'll be pleased to learn that even the most stubborn carpet stains can be successfully purged without the aid of chemical-laden over-the-counter cleaning products.
Removing Grass Stains the Green Way
If you have small children or hyperactive pets in your home, it stands to reason that your carpet has seen its share of grass stains. Fortunately, there is a highly effective way to get rid of cleaning these carpet stains without having to use high-priced commercial cleaners that are loaded with chemicals. Begin this process by thoroughly vacuuming the stained carpet, taking care to remove all traces of dust. Next, obtain an empty spray bottle, produce a mixture of warm water and rubbing alcohol therein and securely seal the bottle. Spray the grass stains with your newly formed cleaning solution, allow the solution to sit for several minutes, then use a sponge, washcloth or scrub brush to vigorously scrub the stained areas. Once the stains have been removed, give the formerly stained areas of your carpet a water rinsing.
Removing Food-Related Stains the Green Way
While it has long been a tool utilized for clothing-based stain removal, club soda can be surprisingly effective at cleaning carpet stains. Club soda is particularly useful for removing coffee stains, wine stains and stains caused by other types of beverages from your carpet. As with the previously discussed grass stain removal process, begin this procedure by running a vacuum cleaner over the dirty carpet, removing all the dust from the area you wish to clean. Once the stained area is dust-free, pour a small amount of club soda onto the stains, give it 1 to 3 minutes to set in, then use a sponge or washcloth to carefully blot the stains off your carpet. Depending on the amount of time between a stain's formation and discovery, you may need to repeat this process several times before certain stains are completely removed. Also, if the stains are relatively fresh, milk can sometimes be substituted for club soda.
Removing Dirt Stains the Green Way
Dirt stains on one's carpet are an unavoidable if children and pets reside in your home, but fortunately, cleaning these carpet stains no longer has to be an ordeal. The next time you spot a dirt stain on your carpet, simply produce a cleaning solution comprising of 1/2 warm water, 1/4 baking soda and 1/4 white wine vinegar in a clean spray bottle. After thoroughly vacuuming the dirty carpet, spray your homemade cleaning solution onto any stained areas and give it a few minutes to penetrate the stains. Lastly, use a sponge, washcloth or scrub brush to clean the stains off your carpet. Follow up by rinsing off any remaining traces of your cleaner with a water-filled spray bottle.
When cleaning carpet stains in your home, just remember these helpful tips and you'll never have to purchase commercial cleaning products again.
