Cleaning New Carpet: What You Need To Know
1-8 hours
Beginner
- 0-200
Cleaning new carpet can be a bit confusing for some people. Professional cleaning can keep the fibers on the carpet clean and not matted down from dirt and overuse.
If there are pets and children in your home, you will need a good method for new carpet cleaning to give your carpet a fighting chance of looking good for a long period of time.
1. Remove Stains Immediately
When you’re trying to keep your new carpet clean, you will want to be sure to clean up any spills as soon as they happen. New carpet cleaning should involve a good management plan for stains and spills.
One of the ways permanent stains occur is when they are not dealt with soon enough after they happen. It is a lot easier to prevent a spill from turning into a stain than it is to remove a stain.
2. Schedule Regular Cleanings
Get your carpet on a cleaning schedule. You can rent professional cleaning machines for your new carpet cleaning. There are some areas of your home that will require more frequent cleanings than others.
Develop a plan for cleaning your carpet on a rotating basis. For instance, in those areas that are heavily walked and will most likely need more frequent cleaning, plan to bring in the equipment twice a year.
Other areas of the home can get by with once a year cleaning. If you are dealing with a heavily soiled carpet situation such as families with small children and pets, you may require more frequent cleaning.
3. Take Shoes Off
One of the best ways to keep the carpet clean is to have everyone remove their shoes when they enter your home. This is the practice of many people, and it is a tremendous way to keep your carpet looking new.
New carpet cleaning will be much easier if you can keep the dirt tracked in with shoes out of your house.
4. Buy a Steam Cleaner
Investing in a steam cleaner or professional grade carpet cleaner is a tremendous way to always have it on hand when a stain occurs.
These machines can be expensive, but they are well worth the price when you consider the cost of replacing your carpet sooner than you really should have to.
The carpet cleaning you can do with your own carpet cleaning machine will ensure you are on schedule and there is no excuse for missing the cleaning date.
Be sure you are using the correct cleaning products for your carpet by checking with the manufacturer. Finer materials may require a dry clean system only and others will be able to use a liquid detergent.
Even if you keep a tidy home, a messy or stained carpet can make the whole house look dirty. Don’t let this happen to you by regularly performing your new carpet cleaning.
