Composite Decking Material: Maintenance and Repair
composite decking
  • 1-4 hours
  • 0-100
Composite deck cleaner or mild soap
Soft bristle deck brush
Broom
Hot water
Bucket Hose
Broom
Hot water
Bucket Hose
A composite decking material is a modern option for homeowners who have previously had only one choice when building a deck, and that is wood. Although wooden decks are beautiful constructions, they require a lot of maintenance and regular sanding and refinishing.
A composite material is made by several manufacturers as an alternative to wood. It offers a solution to the high maintenance problem. The decking material is made from byproducts of wood like wood chips and sawdust mixed with plastic.
You can choose your decking from the various styles and colors that are available on the market, but although composite materials do not require a lot of maintenance, they do need some upkeep. For a start, the deck should be scrubbed and swept free from dirt occasionally. The material can also be stained, and since you cannot sand or refinish it, removing stains should be done as soon as possible.
Step 1 - Sweep the Deck
Sweep any loose debris on the surface of the deck using the broom. Any leaves or sticks stuck in between cracks on the board should also be taken off.
Step 2 - Mix the Cleaners
large composite deck with furniture and plants
Before using the composite deck cleaner, you will have to mix it first according to the instructions of the manufacturer. You can alternatively combine hot water and mild soap in a container.
Step 3 - Scrub the Deck Surface
To clean the deck of tough dirt, scrub its surface using your deck brush. If you want to make your task easier, you can make use of a long handled brush. The tool will also prevent any strain from occurring in your back. The brush you use should have soft bristles to avoid damaging the surface of the decking.
Step 4 - Spray the Deck Surface
Using your garden hose, spray the deck surface to clean it free from cleaner or soap residues.
Step 5 - Repair Mill Marks
To repair any mill marks on your deck surface, you can use a fingernail polish remover. This will lighten the mill marks or remove them completely. Get a cotton ball and wet it with the polish remover. Using a circular motion, rub it gently on the mill marks to remove them. If you want to avoid visible mill marks, you should install the material carefully.
Step 6 - Remove Rust Stains
brown deck with chairs and plants
To lighten or remove stains caused by rust, use a cleaning formula that has phosphoric or oxalic acid. Use it full strength and let it penetrate the stain for 10 to 15 minutes. If you want to avoid having rust stains, you should put away grills and any patio furniture when summer ends so they will not rust and stain your decking material over the winter.
Step 7 - Remove Oil Stains
To remove stains caused by oil, use a soft bristled brush and a household degreaser to scrub the stains away. You will have to remove oil stains as soon as possible, as oil will seep through the material. Once it happens, it will be impossible to repair it.
Step 8 - Remove Fruit or Wine Stains
If the stains caused by red wine or berries are the problem, you can remove them using a solution of bleach and water. Mix ¼ cup of bleach with a cup of warm water. Using a circular motion, brush the stain away using a soft bristled brush. If the stains are caused by berries, they may be permanent, and no amount of repair or cleaning can remove them.
