Build A Stressed Copper Headboard
Sheet of aged copper
  • 4 hours
  • 50-300
Copper sheet in the size required. Many millworks will custom-cut it, which saves you a step.
Liver of sulfur
Bar top rail
Miter saw
Sheet of 1/4" plywood
Jig saw
Nail gun
Tin snips
Wood glue
Finishing nails
Liver of sulfur
Bar top rail
Miter saw
Jig saw
Nail gun
Tin snips
Wood glue
Finishing nails
The ideas for building a unique headboard are limited only by your own creative imagination.
Building a headboard that is as unique as you are takes careful thought and planning, but the actual execution is really nothing more than following a few simple steps.
One excellent idea for a unique headboard is one built from stressed copper.
Copper in its original state is as shiny as a new penny. Finding copper that has been weathered by water and exposure to oxidation may be difficult.
The unique patterns of antiqued copper make an ideal headboard. Here, we will discuss how to build a one-of-a-kind antiqued copper headboard.
The Copper Headboard
Copper comes in many forms. The copper needed here is in a sheet large enough to build the headboard. Companies that sell copper sheeting have it in a variety of thicknesses.
The ideal thickness for an antique copper headboard is at least 1/16", but you can get copper foil that is even thinner. Copper that is 1/16" is easy to cut, and avoids the risk of tearing or wrinkling.
Stressing the Copper
man in a workshop on a computer
The best way to stress copper is to use liver of sulfur. It is both the easiest method and safest to work with. However, like any chemical, it is a good idea to have a metalsmith or jewelry maker do this for you.
If you insist on doing it yourself, follow the instructions on treating copper with liver of sulfur. Very detailed instructions can be found online.
Building The Headboard
The process involves attaching the copper to the plywood, installing a bar top rail, and mounting the headboard.
Let's do this step by step.
Step 1 - Design Your Headboard
A straight design gives character and fits well with the angles of a room.If you are looking for a curved top, building the headboard will be much more difficult. The decision, however, is yours.
Step 2 - Cut the Backing
Using a jigsaw, cut the plywood backing to size. Sand all of the edges smooth.
Step 3 - Cut the Copper
Lay the copper face down on a clean, level workspace. Lay the plywood backing on top of the copper. Mark the edges of the plywood backing, then carefully cut the copper to fit the plywood.
Copper is very sharp, so be sure to wear protective gloves during this operation.
Step 4 - Attach Copper to Plywood
Using the staple gun, attach the copper to the plywood sheet. Be careful you don't have staples showing when attaching the bar top rails.
Step 5 - Cut the Rails
Measuring carefully, cut the bar top rails to size using the miter saw. Cut at a 45 degree angle.
Step 6 - Attach the Rails
Attach the bar top rails to the plywood, covering the staples. Use wood glue and finishing nails to attach, or better yet use a nail gun if one is available. Use the smaller nails to do this.
If the corner angles are not quite matched up, use the nail gun to pull the corners in, being very careful to not split the bar rail, and making full contact with the wood.
Step 7 - Allow it to Dry
Let the headboard rest until the glue is fully cured. Twenty-four hours is best.
Step 8 - Attach the Headboard
Because the headboard will be lightweight, you can attach it to the wall in a variety of ways. The simplest is to use picture hanging materials, and string a wire across the back to hang it.
You can also mount the headboard directly to the wall using wall fasteners.
These fasteners come as two pieces—one attaches to the wall, the other to the headboard frame. Simply slide the headboard onto the mating fastener attached to the wall.
A headboard made of antiqued copper is both unique and fits the décor of most any bedroom. You can stain or paint the bar top rails to the color desired.
Build an antiqued copper headboard, and show it off to all your friends. Need information on bedroom design? Visit our design section.
