Create a Wall Texture Using a Splatter Technique
  • 8 hours
  • 80
Drop cloth
Paints
Paintbrushes
Plastic for furniture
Old clothing
Newspapers, sheets or towels
Paintbrush roller
Paint trays
Drop cloth
Paints
Paintbrushes
Old clothing
Paintbrush roller
Paint trays
A wall texture can add a new dimension to any room in the house especially if it is done with a splattered technique. It is a technique that can be achieved quickly and without much effort, even if you're not a professional artist or painter.
Oddly unique—By splattering paint on a wall in either one, two, three, or multiple colors, you can create a unique wall that looks like a professional actually did it. The finished product often looks like an abstract work of art that is one-of-a-kind and something you can say you put your own stamp on.
Best place—Usually white walls or light-colored walls are the best places to apply the splatter technique. Try the technique in a child’s bedroom or smaller area like a laundry room or a mudroom first to see if you like the final result before applying it to an entire room. Here is how to create an artistic wall design by using the splatter technique.
Step #1: Getting ready
Put on some old clothing. Place a large sheet on the floor or over carpets and then put a drop cloth over it. Cover furniture and other items with plastic. Add newspaper to areas where a drop cloth may not reach such as a tight or small corner.
Step #2: Clean the walls
Make sure that the wall where you plan to add the splatter technique is clean and dry. Repair any cracks or remove marks, scuffs, and hand-prints prior to painting.
Step #3: Paint preparation
Thoroughly mix the color and then pour some of the paint into a clean paint tray. If you plan to use several colors, do one color at a time. You might want to use separate paint trays so paints do not blend together in the tray.
Step #4: Brush and roller
Dip the paintbrush into the paint tray and let it drip down into the tray just for a quick second so the brush is not overloaded with paint. You can also use a paint roller if you do not want to use a brush. A roller will leave winder, longer paint marks.
Step #5: Step back
Take a step back and a few feet from the wall and then fling the brush in the direction of the area where you want the paint to land. Note: Sometimes, paint does not always land exactly where hoped.
Step #6: Please wait
Wait a few moments until the paint adheres itself to the wall and dries. The more paint you put on the brush and fling, the larger the splat and the more splatters you will have.
Step #7: More colors
If you plan to use more than one color, repeat Steps 3 through 7. You can overlap paints and add as many colors as you wish.
Step #8: Let dry between colors
Once you have completed splattering your wall, let it dry for at least 24 hours before adding more paint or finishing with a topcoat. Most splattering does not need a shiny coat that would take away from the rustic appearance.
