Create Homemade Paper Mache
Kids do arts and crafts.
  • 1 hours
  • 5-10
Flour
Water
Cinamon
Salt
Resin glue powder
Newspaper
Glue
Use simple household to ingredients to make homemade paper and art projects using paper mache. This article will show you how to make several kinds of paper mache so you or your children can create many craft items like boxes or masks. Te first step is to mix your very own papier mache glue or paste.
No-Cook Paper Mache
This easy recipe is very simple to make, completely non-toxic, and inexpensive. The formula is simple: 1 part flour and 1 part water.
Stir very well until the mixture forms a thin paste. Use a whisk to remove the lumps and, if available, use a submersible blender. If the smell of the glue is not to your liking, you may add a little cinnamon. If you live in an area with high humidity, you can add several tablespoons of salt to the mixture in order to stabilize it.
Cooked Paper Mache
For the cooked version of paper mache, use 1 part flour and 5 parts water.
Follow the directions exactly as above, but instead mix 1 part warm water with 1 part flour while boiling 4 parts water. When the water is boiling, slowly add the flour mixture to it, whisking it together. Cook the mixture for 3 minutes.
Resin Paper Mache
Unfortunately, this recipe requires a lot of clean-up, but it is the best for work that requires intricate details. Place 3 cups of water in a pot to boil. While you wait, mix 1 cup flour and ½ cup resin glue powder together. Once it is fully mixed, warm up the remaining cup of water and slowly add it to the flour and resin. Add this mixture to the boiling water and mix thoroughly. Allow it to cook for about 3 minutes until the mixture is translucent and smooth.
Pulp Paper Mache
This recipe is great for projects that require finer details. Shred newspaper into small pieces and place them in a large bowl. Add enough warm water to cover the paper and allow it to soak overnight. Dig your fingers into the paper and break it up until it resembles oatmeal. Once you have it as smooth as possible, add salt and mix again, and then try to squeeze out the excess water. You can also do this with cardboard egg cartons if you are pressed for time. If you are an avid recycler, you can even use dryer lint instead of a newspaper.
