Custom Garage Cabinets: Start To Finish
Custom garage cabinets are designed specifically for your garage and are created to fit all your wants and needs.
Benefits of Custom Garage Cabinets
They'll fit anywhere in your garage, no matter how big or small it may be.
Custom garage cabinets are designed to fit your belongings, so everything in your garage will have a place to go.
The Designing Phase
To start building custom garage cabinets, the first item on the agenda is to measure the items in your garage and your garage itself. Once your cabinet's dimensions are calculated, you will need to decide if you want shelves or any other custom accessories. You will design your custom garage cabinets, and then the supplies need to be purchased.
The Finishing Phase (Wooden Design)
Measure and cut the wood for the cabinets, and put it together with nails and screws. You will put the bottom, sides, and top together, and the last pieces that you will attach are the doors. Knobs will go on the doors to open and close them, and then the wood from your cabinets will be stained or painted.
