Customize Your Pool Cabana: 5 Decorating Ideas
A pool cabana can be a useful structure to have beside the pool, giving you a place to relax or to shelter when it is needed. By implementing some design ideas, you can create a cabana that works well with the surroundings of the pool. You will be in a position to put your own design ideas in place.
1 – Canopy
Many styles of pool cabana will have a canopy that is supported by a frame, giving you the option of shelter as well as a cross breeze, if it is desired. The style and design of the canopy can be chosen to meet your desires, as can the manner in which it is draped. You will find there are a range of colors to choose from, in order to create the look that you desire. If your pool decoration makes use of a particular theme, you will also be able to use this when deciding on the pattern that decorates the material used for the canopy.
2 – Paint
It is possible to create a pool cabana made from wood, whether it is an enclosed structure or a basic frame. No matter what style of cabana you have, you will be able to amend the look of it with the use of paint. Changing the color will allow you to match it to the surroundings or even to the canopy used with it.
3 – Ornate
There are many ways in which you can create an ornate design for a pool cabana, allowing you to customize it to your taste. Getting carved wooden posts specially made will help you to create a cabana that looks unlike anyone else’s. A cabana gives you a larger number of options in respect of the extent of the design and decoration that can be put in place. Ornate designs can also be created by molding steel or iron
4 – Lights
An easy decorative touch to your pool cabana is to add lights to the frame. A stylish way to do this is with the use of fairy lights, which can be coiled around the posts that make up the frame of the cabana. Alternatively, larger lights can be attached to other points on the frame to light the area around the cabana.
5 – Style
There are a ranges of different styles available when deciding on the right cabana for you. Decide whether you want an old-fashioned style structure or whether you want a modern look. Dark wood can help you to create a more traditional look, while a modern look can be created with brushed steel. The style of the cabana will also need to be considered in respect of the construction of the structure. This can make the difference between a private space where you can change and make use of the facilities, and an area that is comfortable and designed for relaxation.
