Cutting Polycarbonate Roofing
8-48 hours
Intermediate
- 1.000-15,000
Polycarbonate roofing is gaining popularity among home builders these days. One of the major reasons is the fact that it is highly more economical than other roofing options. Conventional roofing materials are also heavier than polycarbonate roofing, thus you will have to hire more people to install it and adds additional cost. Polycarbonate roofing comes in various sizes and quite attractive colors, thus it will also enhance the overall appearance of the house where it is to be installed. Its aesthetic value then can also be a means to cut down on the cost in terms of house beautification. Here are the steps on how to cut polycarbonate roofing.
Step 1 - Find a Perfect Working Spot
Source polycarbonate sheeting on Amazon.
Use a flat working surface where you can easily maneuver the panel and cut it to the desired length and design. Aside from ease of work, it will also ensure to cut down on your work time. To avoid scratches on the panel, place a flat wooden surface, such as a sheet of plywood, on top of the working table before you place the polycarbonate roofing sheet. Even during the cutting of the polycarbonate panel, the plywood placed below should not be removed. Aside from preventing scratches, it will also help prevent other debris from sticking to the sheet.
Step 2 - Measure the Length to be Cut
Based on the previously identified length required for your roof, measure the length needed on the polycarbonate panel with the use of a measuring tape. Mark the measurements using a fine tip pen. Use a level to ensure proper leveling. For long cuts, it is advised you make a mark on the way through the entire length of the proposed cut to be made, which will serve as a guide.
Step 3 - Cut the Polycarbonate Sheet
Once the measurements are set, prepare the electric saw you will be using. For this type of material, make use of a 90-tooth fine finish blade. Adjust the depth of the saw table to ensure only the polycarbonate sheet is cut. Wear safety equipment such as earplugs, face mask, safety glasses, and a long-sleeved shirt. This is done to ensure that even the tiniest bits of polycarbonate fragments will not cause any injury to you. Start cutting the polycarbonate sheet in a slow and controlled manner.
You can refer to the saw manufacturer's instruction for this. Trim along the line that was earlier made using the fine tip pen. Apply just enough pressure so as to prevent vibrations which may cause cracking of the polycarbonate sheet. Once done, wipe away whatever debris has landed on the sheet. You can make additional fine cuts also when necessary.
