Design a Classy and Inexpensive Bathroom
Bathroom remodeling can be expensive, leading many people to consider discount bathroom remodeling and discount bathroom fixtures. It will definitely pay to think outside the box when it comes to remodeling your bathroom, just make sure that you are still designing a classy bathroom despite the cost savings. Here are some ideas for a classy bathroom that won't break the bank.
1 Prefab Shower
Consider easing back on the idea of a custom-designed shower. Instead, use a pre-fabricated shower unit instead, which will save a significant amount of time and money. If you absolutely must have a tiled shower, then consider fusing a poly shower pan to the tile.
2. Bath Tub Refinishing
Consider a bathtub or shower liner. They are not necessarily a permanent solution, but they will last several years. Bathtub refinishing is a good way to deal with an ugly bathtub without completely replacing it.
3. Consider Repairs
If you are dealing with nicks or scratches, consider repair instead of replacement. Repair is a solid option for sinks, counters, bathtubs, and even your toilet.
4. Do It Yourself
Most of the processes involved in renovating and remodeling a bathroom can be completed yourself. Save money by doing most of the work yourself. Replacing a sink, toilet, or bathroom fixture like a hot or cold adjustment knob will be a generally simple project if you have the right tools and knowledge.
5. Cover Rather Than Replace
Among the best mantras is to cover rather than replace. Hide damage, dirt, and discoloration that you cannot outright replace. Wainscoting goes a long way.
Many people would like to believe that there is no such thing as a cheap or easy bathroom remodel, but that is not the case. Bathroom remodeling can be inexpensive if you are willing to weigh all of your options.
