Design Ideas for Bathroom Tiles
bathroom
Thanks to the great variety of shapes, sizes, styles, colors, looks, and cuts, bathroom tiles offer endless design opportunities. These tiles range from very small to very large, and they can be uniquely designed to create an amazing bathroom.
Micro Tiles
One idea to consider is the micro tile. These tiles are very small. They can be used anywhere in your bathroom, although you should avoid laying them on the floor. It would take a lot of work to keep them clean. Micro tiles can be used as a backsplash behind your sink, or even as a backsplash behind your tub. Micro tiles are classy and contemporary. They come in a range of styles and colors. Showers can also made from micro tiles. It looks outstanding. This process does take a little longer than using larger tiles, but the micro tiles look great. Clear micro tiles look amazing on bathroom counters.
Large Tiles
From one extreme to the next, you could go with the extra large tiles. These tiles can be put down pretty fast, as they are bigger and cover more space. These tiles are used mainly on the floors of the bathroom, but you can use them in the shower too. They come in a range of styles as well but, if you are using these as floor tiles you will need to make sure they are not too slippery. These tiles can be purchased in a matte, non-slick surface, which is what you'll want if you decide to use these tiles on the floor. Taking larger tiles and mixing them with smaller ones can also create a very nice pattern and unique look.
Custom Shaped Tiles
Bathroom tiles can be octagon shaped, brick shaped, and custom shaped. Depending on your needs you can have tile cut to the shape that you need it. A very popular design for bathroom tiles is to have them shaped like stone and applied to the walls in the bathroom. This scheme will turn a very boring bathroom into a very classy bathroom with minimal effort. Stone shaped tiles can be used around your bath tub as well, for added elegance. These tiles look great and are sure to bring the best in your bathroom.
Be Creative
Bathroom tiles are all different. They can be shaped however you need them, and they can make an outstanding masterpiece in your bathroom. Designing these tiles is all about pattern, technique, and uniqueness. Draw your ideas on paper before you go shopping. Bathroom tiles are very popular and will be used for years to come.
