Design Ideas for Brick Driveway Pavers
As an alternative to paving your driveway with concrete, brick driveway pavers offer a viable means of providing a parking and walking space without the need of mortar. Driveway pavers come in a variety of sizes, colors and shapes. If you compare the cost of either hiring a concrete crew to pave your driveway or paving it yourself with buying a number of interlocking driveway pavers, you’ll find the advantage is with the pavers. When you factor in labor, laying brick driveway pavers cost less.
Benefits of Driveway Pavers
Driveway pavers add value to a home that a cracked or crumbling concrete driveway will take away. Brick pavers are stronger than concrete in the aggregate, better able to distribute weight. Additionally, driveway pavers are much cheaper to repair than concrete. Whereas a whole section or even the whole driveway must be repaved if part of it starts to crack, because pavers are individual modular units, you have only to replace the one piece. All in all, brick pavers are a more cost effective means of building a driveway and will save you money and add value to your home in the long run.
Design Ideas with Driveway Pavers
Coming in many different varieties, the design options for driveway pavers are only limited by your imagination. The easiest types of pavers to work with are either square or rectangular in shape. They may or may not rounded or angled corners. One popular method for paving your driveway is to lay the brick in much the same way as a brick wall–with each successive row of bricks shifted half a brick to the left or right. This creates a simple offset pattern that is stronger than a checkerboard layout.
You can also choose to combine both square and rectangular bricks in different colors and create a repeatable pattern, giving your driveway the appearance of a random brick layout. In fact, it may actually be random, but as long as it works, it will be quite a sight to behold. A combination pattern using both large and small patterns is attractive as well. If your driveway has a curve to it, you will have to be a little creative when you lay the bricks. Cutting brick can be burdensome, so look for triangular shapes to augment the square and rectangular bricks. The idea is to make a pattern that has character to it. The best way to do this is to utilize different sizes and colors of brick and to create a semi-random design that is orderly in its apparent chaos.
Brick driveway pavers are far superior to concrete in that they are stronger, more attractive and ultimately less money. The prices may be comparable at the onset, but taking repair into consideration, replacing individual bricks is far less than repaving. In addition, the presence of brick pavers in a driveway actually adds value to your home. Working with brick driveway pavers lets you express your creativity in a very practical way. Rather than a plain slab of concrete, your driveway will consist of a patterned layout full of character and charm.
