Do It Yourself Gas Tank Repair: 6 Important Safety Precautions
2-4 hours
Intermediate
- 25-50
If a hole develops in your motorcycle or car gas tank, an immediate gas tank repair job is in order. There is no need to replace the whole gas tank if there is only but a small amount of damage. Repair kits to deal with a gas tank leak are readily available and easy to use.
Step 1 - Remove Gas Tank from Car
When repairing the gas tank, the first step is to remove the gas tank and drain out the remaining fuel.
Step 2 - Clean the Gas Tank
Lacquer thinner or acetone can be used to thoroughly clean the gas tank. After that, let the tank sit long enough for the fluid inside to completely dry.
Step 3 - Locate the Leak
Now, you should find out the holes in the tank and mark them properly. Make sure you apply masking tape before using the epoxy sealers. This will ensure there is no leakage of the sealer that is poured inside. Use putty to seal the tank outlets.
Step 4 - Pour Sealer into Gas Tank
Use the plastic container to mix the two parts of the epoxy sealer. Leave the solution for some minutes and then pour it inside the gas tank. After pouring the sealer, use a plastic wrap or a rubber band to seal the tank’s filler hole.
Step 5 - Drain Remaining Sealer
Then rotate the tank to ensure there is even distribution of epoxy sealer across different parts of the tank. After rotation, remove the filler outlet plug so the remaining epoxy sealer drains out.
Step 6 - Re-install Gas Tank
The last step is to let the gas tank sit long enough to dry out and for the sealer to harden. Finally, reinstall the gas tank.
Important Safety Precautions While Repairing a Gas Tank
Gasoline should not be used in any case while cleaning the gas tank.
Do not hammer, solder, weld, file, or grind when repairing. A small spark from these instruments can cause an uncontrollable fire in your vehicle or gas tank.
You should wear fuel proof gloves because a small amount of fuel may release when you disconnect the fuel lines.
Use fluorescent bulbs instead of incandescent lights because the gasoline vapors may ignite if an incandescent bulb is broken.
