Dos and Don'ts for Basement Shelves
Basement shelves are interesting ways to store belongings. Traditionally, the basement has been the most neglected part of the house. Fortunately, with the changing times an increasing number of people are paying attention to their basement. A basement can serve as a gym, art studio, play area, living room and many other purposes, if its properly maintained. However, if you chose to use your basement for the traditional purpose of storage you should pay sufficient attention to the basement shelves. Basement shelves play a very vital role is conserving space and storing objects.
There are various kind of basement shelves available in the market. Each one has their own advantages and disadvantages. However, there are some strict guidelines which a person should follow before fitting a basement shelf.
The Do's for Basement Shelves
- Line up your shelves to nose slip shelf liners. Nose slip shelf liners ensure that the storage surface is kept safe and secure. Additionally, you can also use tension rods to hold large trays in an upright position.
- Whenever you build basement shelves try opting for square size support structures.
- Using a block of wood underneath the shelves during construction is helpful, as it keeps the shelves from getting wet during heavy rains or floods.
- If you are going for wooden shelves, always opt for woods like pine or ceder, because they have a better finish and lasts long. Preferably buy planks that is at least a food wide.
- Last but not the least, basement floors generally suffer from the problem of excessive moisture content. Make sure you seal all the moisture points by properly waterproofing the floor.
The Dont's for Basement Shelves
- If you are planning to build a shelf in your basement make sure you don’t congest them. Keep sufficient amounts of space between them, so that articles can be stored in a proper and hygienic fashion.
- If you are planning to build a shelf try to opt for good tools, because bad tools often delays the work and can make you frustrated.
- Don’t store things directly on concrete; try covering them with a carpet.
- Don’t forget to install a de-humidifier and an insulator in your basement. Both these gadgets will not only save your materials, but also extend the life of your shelves.
Building storage units in the basements are really simple. It can be an innovative and interesting task, provided you follow all the instructions properly. It’s important that you follow safety measures. Don’t try to use tools and instruments that you are not familiar with. The bottom line of basement shelving is to add some color and life into the dark areas with minimal cost and maximum creativity, so try using different colors and lights to brighten up the environment instead of spending thousands on expensive tools and plumbing services. Personal initiative will not only save you a lot of money, but will also give you a creative satisfaction that money can’t buy.
