Eliminating Pet Odors: How to Keep Your Hamster Cage Smelling Fresh
Eliminating pet odors can be one of the hardest parts of owning a pet. If you have a hamster, you may find that you have problems keeping your cage smelling fresh. Here are a few tips on how to keep your hamster cage smelling good.
Large Cage
You might want to consider getting a larger cage for your hamster. If you have a large cage, air will be able to circulate through it better and it will not smell as bad.
Bedding
When you get bedding for your cage, you want to get one of two kinds. You can get a paper-based bedding that you can replace frequently or you can purchase a special type of bedding that is designed to reduce odors. Either of these options should help you get the odor problem under control.
Frequent Cleaning
You should get in the habit of cleaning your hamster cage once every four to seven days. This will help you remove the odors before they get a chance to set in. When you clean the cage, you want to make sure that you are not using any harmful chemicals such as bleach. You should be able to use water and vinegar or a gentle chemical that is designed to clean cages.
