Ensuring that Your Soundproof Insulation Batts are Good Quality
Soundproof insulation batt is an insulation made of mineral fiber. This mineral finer is either rock wool or processed fiberglass. Batt insulation is mainly used to insulate below the floors, within walls and above the ceiling. It is the least expensive insulation material and must be installed carefully to be effective. Batt insulation is not a great soundproofing agent to be used alone. It transmits sound through its fibers.
Types of Soundproof Insulation Batts
You can get insulation batts with facing or without facing. Faced insulation batts are used in walls, ceilings, basements and floors. The facing material is a vapor retarder. Gaps in between batts can accumulate condensation or air infiltration. This will weaken the effectiveness of the insulation. Insulation batts need to be installed very carefully.
Fiberglass insulation transmits sound through its fibers. This causes noises to sound like they are amplified. If fiberglass insulation must be used, you need to make sure that it is isolated from the ceiling or the sub floor below you. This applies to walls too. If fiberglass batt insulation touches one side of your drywall, it does not need to touch the other side of the drywall. It is advisable to never depend on insulation batt to work by itself as your soundproofing source as it is not enough. You need the power that comes from lead, loaded vinyl or closed cell foam.
Finding a Good Quality Insulation Batt
When ensuring that you have good quality soundproof insulation batt, there are some quality batt insulation sources that are highly recommendable. To ensure your batt insulation is of good quality, it is recommended to get one that provides excellent sound absorption. Rock wool insulation batts are made of a mining slag. Rock wool is a mineral fiber that looks like a white chopped cotton material. It gives the sources of a dense-like fiberglass. If it is of a dampening structure, it will help to handle the transmission and vibration of sound that comes through that particular structure. You can also get a cotton sound batt insulation type that helps to fill cavities or voids. The difference in a cotton sound batt material is that the cotton does not transmit sound through its fibers as fiberglass insulation does. The cotton does absorb sound, however.
Another great soundproofing insulation is Quiet Batt. It is a premium high-performance and designed for soundproofing both interior and exterior walls and ceilings. Quiet Batt performs better than the standard fiberglass or cellulose and foam insulation acoustically. When installed, Quiet Batt has a tight friction fit between metal and wood studs. This minimizes the energy of sound and thermal transmission. Quiet Batt is a product that can be used by itself or with various other soundproofing materials. Quiet Batt is simple to install and requires no tools. It can be torn or it can be cut with a utility knife. It is itch free and contains no formaldehyde.
