Estimating the Cost to Add a Bathroom in a Basement
If you intend to add a bathroom to your basement, many of the costs associated with the installation are the same as if you were adding a bathroom on an upper level. However, due to the concrete foundation, running water lines and providing drainage require a different process.
Before you begin, make a cost estimation of the project to set a budget and give yourself an idea of what the job entails. If you’re building the bathroom from scratch, many elements are involved, including framing, plumbing, wiring, cabinetry, flooring, drywall, and finishing. Depending on the materials you use, there is an enormous range of potential costs. The initial estimate will directly influence your budget and hopefully convince you to stick with it.
Common Bathroom Addition Costs
While there are some notable differences when installing a basement bathroom, certain basic elements do not change. Start your cost estimation with the common costs. Purchase the materials and have them ready to go. Materials needed to install a basement include those for the wall frames and drywall.
Determine the number of walls and board feet of lumber needed to frame them. Find the area of the walls and estimate the cost for the necessary green board, vinyl drywall tape, joint compound and installation hardware.
Move on to the wiring. Estimate the number of outlets, lights, and switches. Include their appropriate boxes, faceplates, and factor in those costs. Add to that any additional circuit breakers and all of the 12 to 14-gauge wiring that will be necessary.
Fixtures and Flooring
Depending on the size of the bathroom, it may or may not have a shower or tub. It will definitely have a toilet and a sink. Factor into your budget the cost of the necessary fixtures, including a shower or tub.
If you are adding cabinetry, consider the cost of a pre-built variety or the raw lumber. You have several options for flooring, from ceramic tile to slate, granite, or linoleum. Determine the area of the floor, decide on a material, and add those costs to the estimate.
Special Costs for a Basement Bathroom
Because you have a thick concrete slab as a floor, running drain pipes and water lines can be very costly. If you choose the conventional route, you’ll have to dig into the concrete and tap into the main drain line and run water to the fixtures. There are macerating systems which incorporate an above-floor drainage system, which is cleverly concealed.
A macerating drain system is equipped to handle the drainage for the sink, toilet, and shower. It is a cost effective alternative to digging into the foundation or running a connection to the main drain.
With the main costs for the basement bathroom estimated, you can finalize the budget and make any necessary adjustments. Don’t forget the cost of primer, paint, wall decor, and light fixtures as well as any local building permits.
