Exterior Cornice Molding
molding on exterior cornice
Exterior cornice molding adds a historic and sophisticated look for your home. It is a relatively inexpensive way to improve the looks of the outside of your home. Cornice moldings can be put on to embellish the windows and doors of your home and anywhere that you would like to add detail to your home. They add charm and character and are often used to maintain the charm of a historic home.
Make of Exterior Cornices
They are often made from wood, plaster and foam. This is a project that can be done by a do it yourselfer but it requires some research and the appropriate tools that can be costly. But here are some advantages to putting exterior cornice molding onto your home.
Advantages of Exterior Cornice Molding
Increases the value of your home
Adds detail
Makes the outside to the home look detailed
Can hide any imperfections on the outside of the home
The cornice molding is also good at hiding any imperfections that may be on the outside of your home. Such as any brick missing around the door or the windows, this is an easy solution for you if you are looking to fix and improve the outside of your home.
