Facts about Double Glazing Windows
If you want to make your home more energy-efficient, you might want to consider double glazing the windows in your home. Double glazed windows use two separate panes of glass with a thin pocket of air between them to keep air from outside your home from entering inside. Here are some facts you should consider with these types of windows.
Save Money On Power Bills
Glass is an excellent heat conductor, and a single plane of glass used in most windows allows heat to quickly come into your home during the summer and escape out from the interior of your house in the winter. By using two panes of glass, this effect is reduced considerably. This means that your heating or air-conditioning system will not have to work as hard to keep your home at a comfortable temperature level. This results in considerable savings on your power bill.
Reduced Light Use
Double glazed windows not only help keep air from the outside of you home, they also allow the rays of the sun to light your home. This means that you can feel free to open blinds or curtains and save even more on energy costs by not using expensive electric lighting.
Reduced Condensation
By using double glazed windows, you can minimize the freezing of condensation on window glass in the winter. Frozen condensation leads to very cold glass surfaces that make your home feel colder and require more heat to maintain a comfortable setting.
