Faux Tin Ceiling Pros and Cons
Installing a faux tin ceiling can provide you with a number of benefits. However, there are also some drawbacks. Here are some of the pros and cons of installing a faux tin ceiling.
Pros of a Faux Tin Ceiling
One of the biggest advantages of this type of ceiling is the look that it provides. It is very attractive and sought after in the building industry today. It's a high-end look, so people will be drawn to this feature if you try to sell your house.
The obvious advantage of using a faux tin ceiling over the real thing is that it saves you money—a lot of money, actually.
Cons of a Faux Tin Ceiling
When you go with a faux finish over the real thing, it may not look that realistic.
Another potential problem with this type of finish is that it will require maintenance, as opposed to real tin, which is very durable.
